GoPro 3 v P2V+ Wide Angle?
Discussion in 'Phantom 2 Vision + Discussion' started by Fourblade, Sep 1, 2014.
  1. Fourblade
    Warwickshire UK
    I've just looked at a nice clip of a P2V with a GP3
    Couldn't help notice that towards the end of the clip when the camera tilts up to the horizon there is no fisheye effect? I haven't experimented much with my P2V+ as I've only had it a short while, so it's on the stock video settings but I have noticed it's strong fisheye effect.
    Do the other P2V+ video settings reduce this effect?
    http://youtu.be/PbpCk2oua5Q?list=UUWRkTeLqmQfLc8QW8B94pmw
  2. happydays
    Warrenpoint, Ireland
    The narrow FOV setting reduces the induced fisheye quite considerably. It'll still be there, but not as bad as when using the wide angle setting.
  3. locoworks
    i might not be 100% with this, but if the camera is level with the horizon you won't get lots of fisheye at the horizon, the centre of frame is usually ok, it is the top and bottom/ left and right where the fisheye effect is. if the vid was shot in narrow frame mode on a P2V+ the worse parts ( the corners ) are pre cropped. a lot of aeriel shots have the camera tilted down slightly 20 - 30 degrees maybe? to get the ground in the shot so the horizon is near the top of the frame where the fisheye is at its worst. if you have a go pro or P2V+ just look at lined paper or fencing and frame it top, middle and bottom, or left and right for verticals and you'll see where the picture is 'straight'
  4. Fourblade
    Warwickshire UK
    I guess the answer is I need to experiment.... (and have fun at the same time of course)
Similar Threads - GoPro P2V+ Wide Forum Date
P2V+ with GoPro 3 & H3-3D Zenmuse using Litchi app Phantom 2 Vision + Discussion Jul 12, 2015
P2V+ for Sale 5 Batteries & GoProfessional Hard Case Classifieds May 13, 2015
Seting up H3 3D gimbal and Gopro hero 3+ on a P2V+ Phantom 2 Vision + Help May 2, 2015
Swap P2V+V3 camera to GoPro? Phantom 2 Vision + Discussion Apr 9, 2015
Use GoPro H3 3D gimbal with P2V+ Phantom 2 Vision + Discussion Apr 8, 2015
