Goggle Question(s)
So I am thinking of buying the FatShark Dominator V3 goggles. I was wondering
1. When you use the goggles do you still have the iPad setup on the controller? And if so....
2. When you are set up and recording on the Mini USB in the goggles can you also record video or take photos on the iPad as usual?
Any other thoughts about these goggles or any other that is comparable would really help.
1. Yes.
2. Yes. (or, if you have a P3A/P, use the controller-mounted buttons for pics/vids)
Note: I believe that, to connect the FatShark goggles, you may need the HDMI Output Module from DJI.
1. Yes.
Thanks for the reply;
Yes, I am aware and do indeed need the HDMI Output Module.
No, you have an alternative: Tablet from Nivida Shield K1 have HDMI out and also record possibility. With this tablet you do mot have to buy HDMI module. But if you connect goggles to table you will not be able to adjust screen info from DJI Go app.. You get same info in goggles as you get on tablet.
Any reason for buying Fat Shark? Which model?
mactechnic
