Go Pro NOT FPV
Illinois USA
Would there be any problem if I attached a go pro hero 3 to the phantom? It weighs 50 grams and shouldn't matter much right? I'll make sure the wifi is turned off
Do you intend to REPLACE the Vision+ camera or as an ADDITION? It is fine in either case, but do NOT attempt to attach it to the Vision+ factory gimbal or camera.
Dirty Bird said:
That would be just fine. At 50 grams you are adding less than 2 ounces of weight so flight times should not suffer a big hit.
I also have a gsm tracker and the air end of the iPad groundstation
wkflysaphan4
