Gimball will not level horizontal
Discussion in 'Zenmuse H3-3D/H4-3D GoPro Gimbal' started by CamjoRob, Aug 17, 2015.
  1. CamjoRob
    Hello my name is Rob, I am from Netherlands and I have a small problem.
    The Gimball on my phantom2 H3-D3 does not remain horizontal when I fly to the right or to the left, when i fly forward or backward then the Gimball works good.
    I thought it was the Gimball so I replaced it with a new one, unfortunately the problem continues, does anyone here have the solution to this problem.
  2. Mako79
    Sydney Australia
    You may need to do an advanced IMU calibration.
    Do the following:
    Find a levelled surface using a spirit leveller. The more levelled, the better the yaw.
    Find North and point the phantom in that direction.
    When doing the IMU calibration, make sure the phantom has not been flown for an (needs to be cold). The cooler the phantom, the faster and more accurate the calibration will be.
  3. CamjoRob
    Thanks, but i already done that.
    I discovered that the FPV was turned into the assistant, turned this off and everything works now
    Anyway thanks for responding.
Similar Threads - Gimball level horizontal Forum Date
Gimball not working properly? Phantom 4 Pro Help Mar 18, 2017
Professional Gimball Issues Phantom 3 Help Mar 12, 2017
Gimball Motor overloaded Pro/Adv Discussion Mar 10, 2017
dji p2 crashed drone. wires to gimball help Phantom 2 Help Feb 11, 2017
P4 gimball error Phantom 4 Discussion Dec 19, 2016
