Gimbal (X1) won't calibrate properly - P2
I updated my firmware to 3.0 and was unable to properly calibrate the gimbal tilt. When I move the lever back and forth during calibration, the first time I move it it will show the full value range on screen, but then jumps to being stuck at zero. If I move the lever a lot sometimes it will jump a tiny bit, but only enough to tilt the camera up a few degrees and only for a split second.
I tried downgrading to 2.0 but nothing changed...
Anyone had this happen? I may go back to 1.8 and see if that helps... with 1.8 was the only time my Phantom was %100 functional
EDIT: when I search for gimbal calibration, both word get left out of the search because they are "too common"... that is not helpful at all
hi mate... this thread should have your answer, especially the last few posts on page 2. I went through the same thing last weekend
http://phantompilots.com/viewtopic.php?f=19&t=12755
basically, you need to calibrate the rc using rc assistant and fiddle with the X1 tuning screw during that process. afterwards, the x1 calibration in the PHANTOM assistant works properly.
I had to do the whole process like 3 times before I got my X1 lever really smooth
Thank you so much! That is exactly what I needed, it really should be mentioned somewhere.
I'm glad there are rad Phantom phlyers out there willing to help out
people here have helped me quite a bit, I'm happy to pay it forward :)
pitchpost
