  1. dgriffnz
    Alexandra, N.Z.
    Hi folks,
    Silly question time - today I noticed that my Phantom 4 Standard's gimbal moves easily from left to right when the drone is turned off.
    This seemed odd - I could have sworn there was always some resistance to left and right movement - in fact I thought it held itself quite sturdy on that side to side axis.
    ...or am I just mistaken and am going mad? Could the gimbal always have been this "floppy"?
    What's the usual behaviour of the gimbal? It seems to function fine when turned on.
    #1 dgriffnz, Aug 19, 2017
  2. Erised
    Canada
    Yes this is normal when your craft is off. The gimbal has motors (direct drive) that position it, when it's off there is no power to the windings and it just goes limp. And maybe your just getting stronger! lol
    #2 Erised, Aug 19, 2017
  3. dgriffnz
    Alexandra, N.Z.
    Thanks - I'm no noob; I've had mine since July 2016. It's just something I've never noticed before.
  4. dewein
    So Erised... I realize this isn't the P4P Plus area but do you know... Is there a problem if the lens cover is on when the aircraft is powered up? You need to have the aircraft on to do so many non-flying things like updates or using the video editor. Is it okay to just turn it on without taking off the cover? Again, I have the P4P+ but I assume the potential for damage is the same.
  5. Erised
    Canada
    I have a P4 but if you are talking about the gimbal lock that has the lens cover it has to be removed when you power up the bird as the gimbal does the calibration dance, if you forget it on the motors will overload and the craft will power down the gimbal to protect it and you should have a gimbal overload message. In order to change the crafts setting using GO the craft has to be on with the gimbal lock off. If you do this in the house leave the props off for safety.
    dewein likes this.
  6. dewein
    Thanks! Pretty much what my gut told me but I forgot to remove it once and wondered what the possible outcome could be. It's worked okay since but you never know/
    Thanks again!
Similar Threads - Gimbal turned off Forum Date
Phantom 3 Pro gimbal falls asleep after drone is turned on / no signal Pro/Adv Discussion May 8, 2018
Bird returned after gimbal board r/r is acting up Pro/Adv Discussion Apr 6, 2017
Drone returned from DJI with broken Gimbal Standard Jul 9, 2016
Professional Gimbal turned after crash Phantom 3 Help Sep 14, 2015
Gimbal Help Phantom 4 Help Today at 7:51 PM
