Professional Gimbal wheel answer to right stick
Hi guys, I have a crazy issue with the up/down of the camera, after a crash in a tree. The drone apparently didn't suffer at all, everything works perfectly, even the gimbal wheel, but the left command of the gimbal up/down do not answer anymore, unless I use the right stick of the RC, then the gimball move up or down.
I tried every single function of the ap DJI GO, removed it, did again the update, nothing changed.
Any one of you have a solution ?
thk you for your answer and for the try, it have been one of the first thing I did, and no result, when moving the right stick, it keep controlling the gimbal with the right stick controller, and no answer with the scroll...
Do you have an other recommendation on what to do ?
New Threads
ОliverСhristopher
