Gimbal set screw replacement
Discussion in 'Pro/Adv Discussion' started by Phantom fool, Feb 29, 2016.
  1. Phantom fool
    Hi,
    Was flying my Phantom 3 pro and had a crash. Afterward the gimbal would make a grinding noise, so my searches brought me here. It seemed related to the gimbal set screw, so I went to Lowes and bought an allen key set that had a 1.5mm allen key. I adjusted the gimbal arm up a hair and the grinding noise stopped. Then the camera was off center, so I loosened the set screw, adjusted the angle, and tightened. then the noise was back. So, I went through 10-12 iterations of this before I got it right.
    The problem is, After all this I have almost completely stripped the head of the tiny little set screw. I can probably loosen it maybe one more time, but want to replace it. Where can I get one?
    Thanks in advance for your help
  2. TheLightSpeedz
    If it's good leave it alone!
  3. TheLightSpeedz
    Any hardware store will have one! By the way.
  4. rockydog
    London UK
    Google M3 x 4mm set screw.....lots of suppliers on Amazon at around $1.50 for 10
    Sinisalo likes this.
  5. Phantom fool
    That's the info I needed
    Am I the first guy to do this to that little tiny soft screw?
  6. Phantom fool
    Ha! Usually my credo, but I know it's going to happen again
Similar Threads - Gimbal set screw Forum Date
P3P gimbal starts pointing left, not a set screw problem... Pro/Adv Discussion Jun 5, 2017
Gimbal set screw adjustment Pro/Adv Discussion Jun 25, 2016
Gimbal set screw Pro/Adv Discussion Jun 10, 2016
Professional Stripped set screw for gimbal yaw arm Phantom 3 Help Apr 17, 2016
Phantom 3 ADV/PRO gimbal parts (yaw, roll arm, cables, set screws) Classifieds Jan 20, 2016
