Gimbal Roll Limit?
Tony McDrone
Premium Pilot
san diego, ca
I'm getting a message that says I've reached my gimbal roll limit. What is that, and how do I correct it?
Gimble calibration not fix it ? There is gimble adjustment in settings , is this happen in banking turns or normal flight or stationary,,when you hold your drone up power on does the cam follow and tilt corect...if something wrong it should alert you when you tilt drone while holding,,,,
Reactions: Capt KO
I have no idea why that did not occur to me, it is the next logical step. Thank you @ianzone for the help.
I've done the calibration, will get a chance to test later today. Will post the results.
I took a flight immediately following the gimbal calibration. Nothing changed, still getting the message.
cokersean20
