Gimbal Roll Bug in New Firmware?
Discussion in 'Firmware' started by Domenic, Sep 8, 2015.
  1. Domenic
    Just updated to the new 1.4 firmware yesterday and noticed something different today that I never experienced before regarding how the gimbal was operating. Worked fine (or behaved the same way) for months prior to yesterday and fine all day yesterday with the new firmware. Just today during my first flight that I noticed this (video 1). I then turned everything off - rebooted essentially - and took the second video where everything seemed to be normal.
    Example Videos:
    Video 1 - horizontal movement fast and slow to the right and left. Gimbal seems to be malfunctioning.
    Video 2 - horizontal movement fast and slow to the right and left. Gimbal seems to be OK.
    Do you think this was a fluke? Maybe a setting I inadvertently set wrong? Maybe a bug in the new firmware? Anyone ever notice such a malfunction or "feature" ever?
    DOM
  2. envisionabove
    Tim in San Diego
    Are you in follow setting? Or FPV?
    skyhighdiver likes this.
  3. Oso
    Oso
    Western US
    Follow mode vs FPV mode?
  4. brianb87
    That is not correct. Maybe a gimbal calibration? Someone else with more experience might be more helpful.
  5. leekiya
    Lee. UK
    The gimbal seems to be set to fpv, just check it's not in the settings. Hope it's just something as simple as that for ya.
  6. bartold
    I have to agree with all but post 4.
  7. brianb87
    Lol! That's why I said ask someone with more experience! Just tryin to help a brotha out.
  8. Frans Nobel
    The Netherlands
    First video is FPV, video2 is Follow.
  9. Roderick Finch
    I had the same problem yesterday, I did a calibration and it was fine after that.
  10. Domenic
    I never touched any other settings or the PAF button (in the P position both times) on the controller between videos. I just rebooted the bird & restarted the app.
  11. bartold
    My apologies. I thought you were saying everyone was incorrect. I guess you meant that the videos were not correct.
  12. brianb87
    Correct, the video did not look right...Not a problem! I should have made it more clear.
  13. Altanore
    AB, Canada
    In video 1, the setting had to be in FPV mode. The app is known to change settings on it's own without you touching them. Happened to me once. That's why it is always a good idea to check them all including the failsafe settings before flying.
  14. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
  15. Viral
    Your bird switched from Follow mode to FPV, no question. If you've never used it, that's exactly how it works. Mine has switched modes on its own a few times as have many others on here. Just switch it back and you should be good.
  16. Domenic
    UPDATE:
    I have 100% confirmed this is a bug. Today I just turned the P3 on and you can see what is going on in this video:
    By just rebooting the quad it goes back to normal.
  17. louforgiveno
    Fyi, the one of the buttons on the bottom of the contoller is defaulted to switch modes when tapped.....are you maybe accidentally hitting that?
  18. Domenic
    When I shot the two quick videos above I only rebooted the P3 and didn't touch any buttons on the controller. Just moved the stick after it reconnected.
  19. JohnK
    Hudson Valley, New York
    @Domenic have you checked the FPV vs Follow mode setting? You have made no mention of it, but seems to be the obvious first place to look, especially with lou's observation about the buttons.
    The FAP switch has nothing to do with this.
    louforgiveno likes this.
  20. 4wd
    4wd
    North York Moors
    The RH side (probably) rocker switch underneath defaults to FPV or Follow and it can change back to defaults after firmware updates..
    FPV mode is supposed to give more of the feeling of banking as you zoom about, you rarely see it used in P3 videos.
    You need a proper test outdoors after ensuring it is set in Follow either from the app or switch.
    The switch is probably best set to change between Map and Camera.
Similar Threads - Gimbal Roll Bug Forum Date
Standard Can a bad roll motor cause gimbal to malfunction? Phantom 3 Help Jul 27, 2017
Standard Gimbal roll motor seperation repair? Phantom 3 Help Jul 21, 2017
P4P gimbal yaw and roll error - clicking sound Phantom 4 Pro Discussion Jul 8, 2017
Adjusting gimbal roll with right dial Phantom 4 Pro Discussion Jun 27, 2017
"Gimbal roll reached movement limit" Phantom 4 Help May 2, 2017
