Gimbal Ribbon Reinforcement?
Discussion in 'Phantom 2 Vision + Discussion' started by MapMaker53, Oct 7, 2014.
  1. MapMaker53
    Long Island, NY
    Just wondering if this would be feasible.. Has anyone ever reinforced their gimbal ribbon so it can't tear? Years ago, I used to use a roll of metallic/silver tape (maybe metalic mylar) to black out portions of 35mm slides. That tape was pretty much impossible to tear. If that or something similar were to be applied to one side of the gimbal ribbon (I assume the ribbon is insulated), it might make it a lot less likely to tear. Something I might look into.
  2. MapMaker53
    Long Island, NY
    Yep. I just bought and installed that. I guess in reality there is no need to reinforce the ribbon itself if you prevent the gimbal from flying apart in the first place with the bracket.
  3. Panamon Creel
    Central Mexico
    The gimbal can separate/break in different spots or the ribbon cable can be damaged by causes other than the gimbal separating and there is nothing you can do to 100% prevent that so just do what you can and hope for the best if you have a crash ;)
  4. RedBaron
    I just made a template from the cable and used my cutter to cut out a red vinyl adhesive-backed cable protector. I will install this when I get time to take apart the gimbal.
    RB
Similar Threads - Gimbal Ribbon Reinforcement Forum Date
Professional Replaced gimbal arm and ribbon cable Phantom 3 Help Saturday at 7:11 PM
Limp gimbal after ribbon replaced..... Standard/4k Discussion Aug 15, 2017
Professional Replaced broken ribbon cable & now the gimbal doesn't work at all! PLEASE HELP!!!! Phantom 3 Help Jun 23, 2017
Fitted new ribbon, now gimbal goes crazy!! Help please Standard/4k Discussion May 1, 2017
Advanced after changing gimbal ribbon, image is bad Phantom 3 Help Feb 23, 2017
