After I upgraded to 3.04 firmware. Now the response time on gimbal is slow. Any idea of fix?
https://www.youtube.com/watch?v=A5G_cimFGWw
Try to disable FPV mode in DJI VISION app.gh6762 said:After I upgraded to 3.04 firmware. Now the response time on gimbal is slow. Any idea of fix?
gh6762 said:The FPV mode is unchecked. When I try to check the box and hit enter. I will exit the program and restart the program the box is still unchecked.Is this normal? Wondering if I have a software issue.
gh6762 said:Well I un-installed and re-installed the program. I connect USB to main frame of Phantom. Open up assistant and re-calibrate again. Open advance tab no gimbal options. Close program , shut down phantom. Connect USB to camera and open assistant. Gimbal option is there in assistant under advance tab and FPV is un-checked. But when I check the FPV box and hit enter , I exit program and restart assistant and setting hasn't been saved. Is it normal that you cant make and save any changes when connected to the camera. Gimbal is still slow in response only had 3 flights no crashes.
