Gimbal pitch dead
Hi there
My gimbal pitch arm seem to have died. Anyone come across this before? i left it on to drain the power i'm wondering if it has overheat. roll and yaw still keeps the camera pointing in the same direction just pitch is completely free moving.
p3p
Normally when I discharge batteries, I use an external fan to cool phantom. I'm not sure if pitch motor can die if not cooled but kept on. If one is not using an external fan, one can support these motors by external means like stack of papers so that there is no external load on to these motors and the currents in them is thus reduced to minimum.
I still suggest to check the ribbon cables.
thanks. its interesting when i move the camera up and down i can see the pitch display changing on the dji go app. any ideas if its the board or the motor?
cheers
Unplug the wiring harness in front side of VPS and then plug back in. If no change then it could very well be the flat gimbal cable. If replacing, use only oem parts.
cokersean20
