Hi guys
First thread here!
So long story short, I crashed my Phantom 2 with GoPro Hero 3 black on the H3-3D.
The H3-3D lower arm got bent. I dismantled the entire gimbal and re-bent the arm back which is pretty much what it used to be, but not perfect. This is how it looked before:
Problem is the GoPro isn't sitting level when it powers up.
This is how it looks now:
As you can see the gimbal is rolling to the right. Also, I have it propped up since, after the crash, the gimbal sits lower and can't initialise as it touches the ground when I turn it on. Have to try and fix that somehow. Does it look very low to you guys? If you look at the Yaw motor, how much should it stick out of the P2 body hole?
The gimbal is off-balance due to the bent arm not being 100% how it used to be, so i have to now add weight in order to try and balance it again I'm assuming. You can see the blue-tac/presstick I used on the right to try and balance it. Even without this, it still sits to the right as in the pic.
I want to try and avoid dismantling the entire gimbal again just to bend the arm some more if possible.
Would appreciate any advice.
First thread here!
