Standard Gimbal Help
Discussion in 'Phantom 3 Help' started by CaptainRocha, Oct 4, 2016.
Tags:
  1. CaptainRocha
    IMG_4677.JPG hello, i crashed my drone a while back and the gimbal was absolutely destroyed, obviously lost all visual and all the height,velocity stats. im looking to get the walkera g2d gimbal but im skeptical because i don't know if it will work.
    basically the gimbal connect cable (multi grey cable thing) and the dowlink/uplink (grey and black cables) are ripped and i wanted to know if i could install a new gimbal and get my visual and height, velocit, battery, signal strength, etc because all of it is N/A at the moment. Will a new gimbal function without the gimbal connection cable or grey and black ones?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You can install a new gimbal, but you'll only be able to use a P3S gimbal/camera. All of those wires will need to be reconnected/replaced.
  3. CaptainRocha
    so i can't use my go pro on the new gimbal?
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
  5. CaptainRocha
    thanks, do you know what these cables are exactly called and if it'd even be worth it to replace them
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Here are the parts you need to replace those cables:
    I don't know if it'll be worth it or not. The Antenna is no good for sure.
Similar Threads - Gimbal Help Forum Date
Phantom 3 standard Gimbal error(help me) Standard Jan 15, 2018
Help Please Gimbal Repair Crazy Pro/Adv Discussion Dec 29, 2017
Professional P3p gl300b gimbal wheel. Please help. Time sensitive Phantom 3 Help Dec 23, 2017
Rookie needs help w P3 Gimbal dance Standard Dec 16, 2017
Please Help! P3P Gimbal Woes Pro/Adv Discussion Dec 15, 2017
