Gimbal guard
Discussion in 'Pro/Adv Discussion' started by drones2sky, Feb 13, 2016.
  1. drones2sky
    Hi guys. As reading and investigating I am to the next buy of a gimbal guard. Does any one has any experience of a certain brand and how easy is to attach? Also the extra weight added to the drone? I saw tha polarpro has one. Please share your thoughts
    Thanks...
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    They are very easy to install -- snap it in between the landing gear. The extra weight won't be a problem. You can find a list of commonly used gimbal guards here.
  3. drones2sky
    Hi msinger. Do you happen to use one?
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I have a 3D printed guard (that was accidentally shipped to me), but I don't use it because it pushes the landing gear apart just far enough to make it impossible to slide my Phantom into the case. I had a carbon fiber UAV BITS guard on my P2V+. Their products are made very well.
  5. drones2sky
    Thanks misnger. Just for protecting the camera I will buy one. Xost of destroying a camera is mush more tha 10-20 $
  6. CaptainDrone798
    Canada
    I use the same model Gimbal Guard on the P3A and P3S. Although I did have to modify the one for the P3S because the landing gear is different. Purchased them off Amazon. Do a search for BTG Gimbal Guard.
  7. drones2sky
    Thanks very much for your reply. It is very important to have this on. Do you just slide it between the landing gear?
  8. CaptainDrone798
    Canada
    Well you kinda slightly bend it into place. The P3A/P3P has two tiny pieces of plastic sticking out (per side) on the bottom landing gear struts. The Gimbal guard has two groves cut into each side which snap into those pieces of plastic. It stays on really secure. Look for a Gimbal guard that shows two tiny groves at each end.
    The P3S only has one piece of plastic per side which means you either have to modify a Gimbal Guard (cut a grove in the gimbal guard to match) or try and locate a Gimbal Guard specifically for a P3S. For the P3S look for a gimbal guard with only one grove on each end.
  9. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Most gimbal guards have holes around the areas where they slide into the landing gear. Some people (like me) wrap plastic zip ties around the gimbal guard and landing gear to semi-permanently secure it. That'll prevent it from popping out if you crash.
  10. Kima kim
    Msinger, would it really matter if the gimbal/camera would slightly touch on the Guard during the start-up dance?
    If it would, I was thinking I can just press down on the Guard a bit during start-ups.
  11. out_droning
    What's the advantages of a glimbal guard?
  12. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Not sure. Only time will tell if it would cause any damage after doing that motion over and over again. If that happened to mine, I would return it and look for a guard that fits properly.
  13. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It's supposed to help protect the camera in a crash.
  14. Kima kim
    Thanks!
  15. out_droning
    Thanks.
Similar Threads - Gimbal guard Forum Date
Professional Is there a gimbal protector/guard/lock kit. Phantom 3 Help Aug 3, 2017
PolarPro Gimbal GUARD ON PHANTOM 3 STANDARD Standard/4k Discussion Jul 27, 2017
dji phantom 3 standard gimbal guard Standard/4k Discussion Jul 15, 2017
Phantom 4 Pro – Gimbal Guard Causing Flying Errors Phantom 4 Pro Discussion Jun 16, 2017
Phantom 4 Pro Stops Mid-Air, Gimbal Guard Phantom 4 Discussion May 30, 2017
