Professional Gimbal Grinding Noise
Discussion in 'Phantom 3 Help' started by Nightcast, Jun 25, 2016.
  1. Nightcast
    So when I use my gimbal is sometimes makes this grinding noise. Doesn't do it all the time so im not sure what is causing it.
    Here is a video of the issue, you can hear it as it beeps.
  2. With The Birds
    Australia
    Has the camera/gumble taken a hit?
    Seems it cant centre itself on the roll axis, like the position sensor is out of whack and the end range of movement isnt physically where the sensor exoects it to be and its trying to drive itself past the limit.
    Its definately not centering level after it tries to initialise itself.
    Nightcast likes this.
  3. Nightcast
    I don't think it has, Everything still looks good on the videos and gimbal goes every way it should. Just makes that noise and doesn't stay level sometimes.
  4. hunch
    look on top of the yaw arm. you will see a 2mm hex in there. tighten it. that's your problem
    see the picture below
  5. Nightcast
    Well I'll be damned, that was it. Thank you much.
  6. hunch
    no problem brother. glad it worked!
    hani
    Bailey5 and Nightcast like this.
Similar Threads - Gimbal Grinding Noise Forum Date
My Phantom 3 Standard makes a gimbal grinding noise when recording Standard Feb 21, 2017
Gimbal grinding noise P4P Phantom 4 Pro Help Jan 23, 2017
Gimbal grinding made me sad :( Standard Dec 3, 2017
Standard Gimbal grinding sound Phantom 3 Help Jul 19, 2017
Slight grinding sound coming from gimbal? Phantom 2 Vision + Help Jan 9, 2016
