Gimbal design changed?
Discussion in 'Phantom 2 Vision + Discussion' started by ryanhoelzer, Aug 7, 2014.
  1. ryanhoelzer
    I don't think I'm imagining it but it wouldn't be the first time..
    I was looking closely at the new gimbal on my P2V+ and it seems like there are slight differences. The first thing I was thinking was the routing of the ribbon cable but I can't seem to find a picture of another one to compare. I did notice one of the pieces of the gimbal is at least a little different, see the arrow on the pic and compare to yours.
    Maybe the wait was for improvements?
    Please post pics if yours looks different.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. rrmccabe
    Ankeny, Iowa
    Looks similar to mine.
      File size:
      87.3 KB
      636
  3. ryanhoelzer
    Here's the one I had found with a different piece. Angle is funny but obviously a little different.
    [​IMG]
  4. Jstic
    DJI needs to reinforce the elbow connection where the ribbon cable is. I am no engineer, but cannot believe that this would be an impossible task.
  5. ToThePoint
    Antwerp, Belgium
    I've got the same gimbal.
    It came with it when i bought it some 2 mounts ago.
  6. fastsmiles
    Fort Worth, Tx
    They have beefed up the gimbal arm, by leaving more metal in the upper portion.
    Here is a picture of mine, bought in May.
  7. fastsmiles
    Fort Worth, Tx
    Comparison
  8. ryanhoelzer
    That's what I was seeing. Just makes me wonder if they changed anything else.
  9. ToThePoint
    Antwerp, Belgium
    Yep mine is different, it doesn't have that small cut away.
  10. fastsmiles
    Fort Worth, Tx
    Check the plastic body above the gimbal where it makes contact with the vertical shaft. This has been blamed for causing damage to the camera in cases where the Phantom lands upside down in a crash and the inertial forces are transferred along the arm. (its not the fall that kills you, its the sudden stop at the end)
  11. Falcon
    Hi there.
    A fellow Spain has protected the ribbon cable from the camera with hot glue.
    See the link.
    Incidentally, my Phantom also fell and broke the camera as has happened to you. Now I have the camera with her gimbal in Germany to make me a budget.
    http://www.todophantom.com/como-evitar- ... mofusible/
    Greetings.
  12. Mori55
    NJ-USA
    I wonder if we could beef the arm up by putting JB weld epoxy in the arm wear they beefed it up ? How about removing the plastic on the shell were the vertical arm is ?
Similar Threads - Gimbal design changed Forum Date
Phantom 4 Gimbal Design Flaw, the Reason for Overload Error! Phantom 4 Discussion Jun 1, 2017
Design flaw in the Pro3 gimbal? Pro/Adv Discussion May 12, 2016
New Gimbal Lock Design Classifieds Jul 8, 2015
NEW P3 Gimbal Lock and Lens Cap design Pro/Adv Discussion Jun 2, 2015
DJI addresses gimbal motor separation problem with redesign Phantom 2 Vision + Discussion Jan 13, 2015
