Gimbal acting erratic
Discussion in 'Pro/Adv Discussion' started by Ricky T, Apr 14, 2016.
  1. Ricky T
    I had a crash last week and it appeared the only damage was the gimbal vibration mount cracked. I ordered a new one and put it on today. When I started the bird up the gimbal went wild. I've tried calibrating CMU and gimbal. Anyone seen this before or know what it could be
  2. Ted4797
    Florida and New York
    What do u mean by wild? Can u put up a video?
  3. BDOG
    San Jose Ca and Lake Tahoe NV
    Ripped or slightly pulled out / disconnected ribbon cable to the gimbal . Possible...
  4. Ricky T
    I'm trying to put up a video of it from my iPhone but it's not letting me. I will try again. By wild I mean it spins completely out of con
  5. Ricky T
    It spins completely out of control and is getting hot. There's no visible damage at all but at startup it goes evert direction possible pretty quickly. All cables are secure
  6. Ricky T
    If it's the gimbal bad I will just sell it all on here
  7. Ricky T
  8. BDOG
    Yeah , that's pretty wild! No idea on this issue.
  9. Ricky T
    Me either. Hard to describe lol
  10. Air Ontario
    U.S./ Canada
    Post your sensor readings. Acts like it has no idea where 3D level and horizontal is or has a bad ribbon or gimbal main card.
  11. flpholt
    palm harbor florida
    its the new dji gimble dance
  12. Ricky T
    Cool. Still in beta
  13. Air Ontario
    U.S./ Canada
    Just a data point for you to consider...
    With the impact at the flange there may be a cracked main board on the gimbal. Pretty easy to check, 4 screws and a slide plate if I remember.
  14. alokbhargava
    San Francisco, CA
    This is a clear sign of loose connection. Hope lose connection is on the cables side. Check gray cables and black ribbon cables for any looseness.
  15. Ted4797
    Wow. I have seen that when the camera is 180 degrees off during a rebuild. Never on a crash only. By the way, I would love to fix it and see what is wrong. Do u want to sell it?
  16. Reed L
    Alta, Ca.
    Looks like a Standard. On the clips that fasten the camera to the mount, push the plastic fasteners or washers up onto the plastic shaft to stretch them open for a few minutes and then when pulling them off, do it quick. They're kind of a pain but after that you can remove the camera and go flying or at least make sure it still flies. When putting it back together, you can re-use them this way. I've switched those out for zip ties on mine for a bit more give like a shock absorber for my next crash on my P3A. The first time, I simply gorilla glued the camera mount back together and it still works fine. Then if it fly's fine, you can decide where you want to go from there.
    I see that you have already taken it off... So forget the first part :) I left it for others... You should recheck the cables where you put them back together. I flew mine without the camera for a while because it really is quick and fun to fly with that weight of the camera taken off. You might need a new ribbon cable and the cable sets are cheap on Amazon. I carry a spare set in my crate.
    http://www.amazon.com/Genuine-DJI-P...s=DJI+Phantom+3+professional+ribbon+cable+set
    http://www.amazon.com/DJI-Part-Cabl...&redirect=true&ref_=oh_aui_detailpage_o00_s00
  17. Mako79
    Sydney Australia
    I think the hidden hex grub screw is loose. Look for the black hex grub screw at the top of the arm near the base of the gimbal board. It should be on the opposite side of the flex cable. Tighten it to the flat side of the D shaft. Let us know how you go..
  18. Ricky T
    Grub screw is tight.
    I opened the gimbal up and everything looks fine. No loose connection or cracked board that I could see. Still looking. Thanks for the assistance everyone
  19. butcharuski
    Mine just started doing the same thing... The only thing I noticed that could be the problem was that my ribbon cable looked like it was separating at the "corners"... I'm going to order a new ribbon cable and see if that fixes it.
    [​IMG]
  20. Ricky T
    I had mine apart yesterday and all I could see was the sharp bend in the ribbon cable where it goes into the camera its self. But I took the back of of it and powered the drone up and there's a green light on the board that lighted up. Makes me think there's not a problem there. I also ordered a cable set. Im going to replace mine as well. Did you by chance have a hard crash before yours started acting up?
Similar Threads - Gimbal acting erratic Forum Date
Bird returned after gimbal board r/r is acting up Pro/Adv Discussion Apr 6, 2017
Standard Gimbal acting crazy!!! Phantom 3 Help Mar 25, 2017
Gimbal acting weird Phantom 4 Help Nov 21, 2016
Gimbal ACTING FUNNY. Pro/Adv Discussion Jun 25, 2016
Gimbal not reacting- App says I should remove gimbal-protector Phantom 2 Vision + Help Apr 8, 2015
