Getting no connection
Discussion in 'Pro/Adv Discussion' started by Dronebow, Nov 23, 2015.
  1. Dronebow
    Texas
    I think it's been since the latest firmware that I started noticing this issue. I have always followed the documented way to power components on.
    - Power on the Remote
    - Power on the Quadcopter
    - Power on the DJI app
    This has always worked and until recently it doesn't always. What happens is that the DJI app reports no connection to the quad. I can power off the remote while leaving the bird powered on and then power the remote back on (not doing anything to the DJI app) and this will normally correct the issues.
    Has something changed in the firmware or has anyone else noticed this behavior? Once it's connected it seems to be fine. But it's a bit unnerving when something doesn't work as expected.
  2. Ptr
    Ptr
    The documented way you power on seems to be wrong according to DJI
    in saying that I have to power up your way so I can hit trust this computer blah blah blah, looks like right is wrong & wrong is right
  3. kcochran
    I'm having trouble connecting period. Get "no signal" quad flies but no connection to camera since update. Will try this alternate turn on sequence and see what happens. Have always done RC, app then quad.
  4. alokbhargava
    San Francisco, CA
    Try if you can start P3 with RC even though you don't see connection. If this is the case, it points to a bad connection between RC and phone/ tablet.
Similar Threads - Getting connection Forum Date
Getting very annoyed with antenna connections SMA Standard Mar 1, 2017
Remote Controller getting warm, then connection lost & RTH? Phantom 2 Discussion Nov 27, 2014
getting started with Litchi Control (Go, Litchi, etc..) Jan 11, 2018
Phantom 4 getting a fly by Photos and Video Jan 8, 2018
You were worrying about getting motors wet.... General Discussion Jan 7, 2018
