Getting exposure ring of the screen?
Waterford, Michigan
How do I remove this off the screen while I’m trying to fly?
I don't have my drone with me, but the option is in the camera settings. You can also press the X in the corner and it will go away.
Yeah, same-o the x should clear it off of the screen?
Rod
I must not have hit the x correctly because I tried that. I’ll try it again next time. Why is that ring displayed in the first place? Is it letting me know my exposure setting needs adjusting?
You might need to switch exposure depending on what you are looking at in the screen. Darkers need more exposure, so being able to tap your screen to get the correct exposure is a plus.
Whats in the ring is were your camera is measuring the light, otherwise it is measuring the whole frame.
I run mostly missions around my house and I want to see the land.
I tap on the lower half of the screen to bring up the ring, after the mision starts and I have adjusted the camera angle.
Rod
hirehackers
