FUTABA T8J Setting for Phantom Vision
Hi,
I used to a phantom and now I bought a phantom vision.
Would anyone be able to assist me in terms of the settings I need if I use a Futaba T8j for the phantom vision?
HI,
Both the transmitter and receiver is Futaba. Not using the transmitter from the vision.
It is not going to work and you are going to crash or to loose your phantom.The tx of the vision is 5.8 ghz and the downlink for fpv is 2.4 ghz.The futaba tx is 2.4 ghz the same frequency as the downlink, it is going to interfere and after some distance you are going to lose control of your phantom.
Sent from my iPad Air using Tapatalk
HI guys,
Thanks for the earlier replies.
If I were to remove the receiver of the vision and the stock camera and replace it with the h3d gimbal and a futaba t8j, will it now work?
All im really trying to achieve is in using the futaba for the vision.
wkflysaphan4
