JTheed said:
Gizmo: You'll have to explain about the Timers. I've only had the Phantom a couple of weeks and this is all new to me. I've read a lot but don't remember reading about any timers unless you are referring to the ones in the 4.02 NAVA update?
see page 42 of the manual.
(I highly recommend downloading the pdf of the manual online from their site, easier to search thru and brush up on than the paper manual)
The Futaba T8j has 4 timers , two (the big ones) of which can be programmed to be triggered/run when the throttle is above a given percentage.
You put your throttle at the 0% position, set/reset the timer to the start at 0.
- and they won't start counting up or down UNTIL you move the throttle up (presumably when you start the motors and take off).
then you have a totally accurate timing of your flight (it beeps ever minute, and then beeps even more when it approaches a target end time.
For me, I have one timer time down from 5 minutes to 0, so I can land before my Phantom goes into battery failsafe.
and then I have 2nd time count UP from 0 . and beep at 6 minutes but will continue to keep counting up until I put the throttle at 0%.
Then when I leave my throttle at 0%, I can then glance at any time after my flight to see how long the flight was truly for.
If you have a center sprung throttle, you really have no way to use these timers ideally, as you'll have to remember to reset them JUST before takeoff, and glance down at them the moment you land - other wise when the throttle springs to 50%, it will let the timers run on.
the 3rd and 4th timer are really basic timers, used to time out how long you've been flying with a Model (MDL), and System
I just use the System timer to time out my TX batteries (just a little easier then going by the volts that are displayed.
