Mannyx said:
any other way so i can use my futaba to PV2+? thanks for the reply
Sure, you replace the Control RX unit with a standard 2.4GHz Phantom2 RX which is Futaba FASST compatible which the 14SG is.
However to avoid interference you would have to remove the 2.4 GHz FPV transmitter which makes the V+ gimbal useless thus you can get rid of that one too which would leave you with Phantom 2 former Vision+
Better of to get a standard 2.4GHz P2 with a Zenmuse gimbal GoPro and 5.8GHz Video transmitter setup if you absolutely want to use your 14SG or even better stick to your
little white DJI transmitter
