Front LEDs will not light!
Discussion in 'Phantom 2 Vision + Discussion' started by The Famous, Sep 4, 2014.
  1. The Famous
    Was showing a friend my Phantom. We were under a tent and it was raining. I opened the case and just them someone hit the tent to splash us with water. No water got on the Done but a little got on the foam in the case. I did not get to open the case for two days an today I wanted to show a fiend the Phantom. The Phantom had moisture on the top he body and the camera & Gimbal also had some moisture on them. When I powered it up, the front (red) LEDs would not come on. Tried to boot up several times but no luck. I started the Phantom in the "idle" mode and the front right rotor was spinning slower than the others. The camera works. I tried to "search" and found the rice trick. Would this be the cure?
  2. DBS
    DBS
    Ft. Pierce, Florida
    Would have been the cure if you did it when you noticed the moisture in the first place... might still work but powering up and trying all that stuff may have damaged something permanent...
    If you are gonna dry it out... multiple days is the key... let it go for a week and THEN try powering it on... don't keep checking it every day just to see if it's better yet.
  3. mickey78
    Stop using it, remove your battery and let it dry for a few days. The rice thing is a good idea.
    I'm afraid you may have worsen things by "trying it" like you did...
  4. The Famous
    I placed rice in a small garbage bag and placed the Phantom it and seal it. 4 days later I opened it. It worked! The only thing, one of the motors, when I start to put power to it from the idle position, stops for a second and then starts to spin as the others. Going to replace the motor. Don't trust it.
    Thanks for the rice tip.
  5. mickey78
    Yeah i would replace it also. Don't forget to eat that rice :)
Similar Threads - Front LEDs light Forum Date
Any way to replace front red LEDs with landing lights? Pro/Adv Discussion Jul 5, 2016
Professional front red led lights and extra channel for chaser leds Phantom 3 Help Jul 23, 2015
P3S Front LEDs out Standard Jun 2, 2017
Front Leds Phantom 4 Discussion Dec 5, 2016
Professional Front LEDs on P3 not working Phantom 3 Help Sep 7, 2015
