t9rob said:Hi,
Yes drilled the front of the Phantom and installed a stripped down Dot-It LED
http://www.osram.com/osram_com/products ... /index.jsp
Soldered a new cable to the LED pcb and attached it to 2x CR2032 batteries which are easily housed in the fuselage. The hardest part was installing the PCB behind the USB ribbon cable.
t9rob said:Left them running for several hours and no burn out problems.
The on/off button is just visible in the centre of the LED cluster.
t9rob said:No outdoor photos yet.
In very bright conditions the drone needs to be almost directly in front, facing me to see the LEDs. It's better in dull overcast conditions. When I next get the opportunity I'll try and bag a couple of snaps of it in the air. The reason I installed them was that when using the FPV to fly the drone away some distance, I struggled to get eyes on it when I looked back up. My theory was to rotate the drone through 360 degrees and hopefully spot the bright LEDs.
Sasquatch said:I really like the basic concept, it's something I have been asking and wondering about. For me though, I would have to be assured that the forward facing 'flight lights' were easily seen during the day. I've seen similar mods on the older PV's and the LED's looked bigger and brighter. Also, it would be best if the light(s) were hard wired to the main board negating a separate power source and so that the lights could be turned on/off with the unit's power on/off cycle somehow.
