FPV transmitter blocking gps
Discussion in 'General Discussion' started by Davek, Dec 16, 2013.
  1. Davek
    Austin, TX
    I installed this FPV system this weekend with the egg beater antenna's. I still have some display issues using that igrabber device and guess I'll go a more traditional route. But the deal is that I did mount the antenna upward off to one side. I know the gps antenna is there in the middle and it is preferred to mount video antenna downward because it's generally above you. This 1.3mhz antenna is big and just didn't like the looks of it. So anyways, I turn on everything and wait for boot up and ph fails to get any gps..... 3 reds with the one green. I tried this a few times over 24 hours. Then I cut the power to transmitter and left everything in place and ph gets gps now.
    Do you guys believe it's because the transmitter is too strong (800mw) or is it antenna location?? I also figure if I mount it downward, it'll effect the compass too.
    http://hobbywireless.com/index.php?main_page=product_info&cPath=117_88_90&products_id=951
  2. kenskid
    Your experiment answered your question. I would just mount it on the underside. I have a fatshark 600mw on mine and don't have GPS or compass issues. Try different spots if you can. I use Velcro, not screws though!
  3. Davek
    Austin, TX
    That's an idea, I'll try outside the case. Might help with heat as well. The antennas are rather large in this freq so it makes it harder to mount.
  4. kenskid
    Yes. On the outside much better. Especially for people like me that can't glue two pieces of wood together.
Similar Threads - FPV transmitter blocking Forum Date
Multible FPV goggle on 1 transmitter Phantom 4 Help Jul 28, 2017
Sinopine 5.8GHz FPV Transmitter Standard/4k Discussion Jun 16, 2017
Phantom3 fpv external video camera & transmitter Pro/Adv Discussion Mar 22, 2017
FPV Transmitter to Monitor *HELP PLEASE* Phantom 2 Vision Discussion Dec 24, 2016
Phantom 4 transmitter with fpvlr boosted Classifieds May 29, 2016
