- Joined
- Aug 11, 2014
- Messages
- 3
- Reaction score
- 0
Hello fellow pilots!
I'm having trouble getting a clean signal to my Black Pearl monitor from my dji Phantom 2. I've attached a picture for reference and I will do my best to explain my configuration.
PHANTOM SETUP
+The Zenmuse H3-3D is rigged out with my Hero 3. I am running the HUB-ZEN cable from the Gimbal to the top 8 Pin HUB input.
The 8 Pin HUB input running under, is connected to the 8 pin wire coming from the chasis of the Phantom.
The iOSD MINI input on the HUB is connected via mini cable to my iOSD Mini and the iOSD's cable connect's to the Phantom's iOSD cable input.
The VTX HUB input is connected to the AVL58 Transmitter which has the TX antenna. Once powered up, the AVL58 Transmitter blinks a single YELLOW and GREEN, which I believe marks "Channel 1".
All my connections are secure and I was extremely careful with set up, yet I am not getting a clean signal.
BLACK PEARL SETUP
My AVL58 Receiver has an RX antenna and has a 1/8inch to RCA going in to a YELLOW RCA cable, which is connected to the AV IN on my Black Pearl. Once powered up the Receiver blinks a single YELLOW and GREEN.
The Receiver is powered directly by DC power from the Black Pearl.
Everything is set to F Frequency.
I hope this has been descriptive enough! So again, what's happening is a very distorted signal is all that I see on my Monitor. I am looking for any help or tips on how to trouble shoot this problem. Thank you so much for your help fellow Phantom pilots!
-Brendan
PHANTOM SETUP
BLACK PEARL SETUP
-Brendan
