FPV Tablet question
Discussion in 'Phantom 2 Vision Discussion' started by slicknet, Feb 1, 2014.
  1. slicknet
    Southern New England, RI
    I am looking to get something bigger than my Samsung S3. Have seen posts where the Samsung tablet has given people problems. Has anyone tried the 16GB 1.2GHz 7" Google Andriod 4.1 or does have an alternative. Would like to stick with the andriod format. Thanks
  2. Pull_Up
    South Oxfordshire, UK
    Everyone using a Nexus 7 seems to be happy with both the performance and screen brightness...
  3. slicknet
    Thanks Pull-up, I'll check that out.
  4. Count
    Using the Nexus 7 here, with no issues at all. Only complaint is the glare. I just ordered an anti-glare film...
  5. FPV col
    I am also using the nexus 7 works great with zero issues..
  6. Seahorse
    Hampshire, UK
    How are you mounting them on the controller?
    What hood or filters are people using and are they effective?
  7. pault
    Liverpool UK
    +1
  8. FPV col
    I have mounted my nexus 7 on my patch antenna tripod conversion.. For me it is a bit big to TX mount although some have.
  9. Pull_Up
    All sorts of homebrew adaptions have been made, and some have slightly modified off-the-shelf holders to work with the existing transmitter clip's ball joint.
    The simplest one I saw was using the stock clip with a piece of pvc plastic or similar that had been shaped into an elongated "S" - put the bottom of the tablet onto the bottom jaw of the slip, hook one end of the plastic S over the top of the tablet, hook the bottom end into the top jaw of the stock clip. Simple, secure, instantly swappable if you want/need to use your phone for some reason.
  10. gunslinger
    gunslinger Moderator
    Staff Member
    Least Coast...
    Same here. It was overcast yesterday, so the Nexus 7 was absolutely perfect. Please let us know how you make out with the anti-glare film.
    Thanks...
    -slinger
  11. karlsch
    It seems there are two Nexus 7 models. The original and the newer 2013 model.
    Do the original, older Nexus 7s work OK? They are still available and are cheaper and I will only use it with my Phantom Vision.
    I already wasted $180.00 on a Samsung tablet that I will donate to the Salvation Army because it doesn't work.
  12. wildcatter
    Canton Iowa USA
    If you use the search bar and type in nexus 7 it will take you to a thread that has all the answers......
  13. FPV col
    I can only say the 2013 Nexus works fine as this is what I use..
  14. gunslinger
    Staff Member
    Least Coast...
    I have the original Nexus 7 (because I'm cheap !) It works fine. Never had a problem with it.
    -slinger
Similar Threads - FPV Tablet question Forum Date
Fpv-tablet and phone. General Discussion Jun 7, 2017
my samsung tablet isnt bright enough for fpv Phantom FC40 Discussion Apr 25, 2017
Tablet FPV Standard/4k Discussion Dec 20, 2016
FPV image quality on a tablet Pro/Adv Discussion Oct 28, 2016
Using a Tablet and FPV goggles at the same time Pro/Adv Discussion Sep 24, 2016
