FPV signal fuzzy
Hello,
I'm reaching out to all the experts out there for help!!
I just finished my FPV setup on my Phantom 2 -Zenmuse H3 3D -Go Pro Hero 3 + Black edition with the following..
-DJI IOSD mini
-DJI ALV58 Lite
-FPV Hub
-Lilliput 664/W FPV monitor
Prior to this I had already installed the interference board internally.( should I remove this board now that I have the above installed)
In any event, I took it for a test flight to find out that the signal/image has ghost lines like an old TV out of tune. Does anyone have an idea what could cause this?
Any advise will be greatly appreciated
Thank You
The AVL ends in 5's in the frequency does your lilliput do the 5's or the 0's? Mine is with the 0 one but there are two versions
If its the same are you sure you have the same frequency selected?
Be sure to check the the connectors on your antennas, mainly the center pins of the connectors, make sure you have male to female etc. and not a female to female.
cokersean20
