FPV Options
Discussion in 'FPV (First Person View)' started by Keith Pawley, Aug 1, 2016.
  1. Keith Pawley
    Hi all,
    I have had a phantom 3 professional for a few months and want to go down the FPV route,
    please could anyone give me some advice of my options.
    Should I go down the VR goggle litchi/cloudlight route or the Fat shark option?
    If the litchi/cloudlite option what are the best VR goggles and what software? (I have a iphone 6plus).
    Thanks in advance.
    Keith
    TheFPVdrone likes this.
  2. Pharm
    Technically, FPV is what you've already seen on your Iphone screen while flying. As far as VR, Litchi seems to work well as long as you know it's limitations. In VR mode with head tracking and a few other modes, be aware that if you lose contact, your Phantom will NOT RTH. It will hover instead. I'm not familiar with the capabilities/limitations of the other ones you've mentioned.
  3. Keith Pawley
    Thanks very much for the information.
  4. Procharged97
    Canterbury, CT
    I thought it will only hover using the standard and 4k a/c?
    Sent from my SAMSUNG-SM-G730A using PhantomPilots mobile app
  5. Procharged97
    Canterbury, CT
    WarningWhen using a Phantom 3 Standard or Phantom 3 4K (not to be confused with Phantom 3 Pro), be aware that the aircraft will not return to home automatically if signal is lost while Litchi has some or all control of the aircraft, it will hover instead. The following flight modes are affected: VR with Immersive/Joystick Head Tracking active, Follow, Focus and Track. All other aircraft models and flight modes are unaffected by this issue.
  6. Pharm
    You are correct, Kimmosabe. Forgot to mention that AND the OP has a P3P so it shouldn't matter anyway. Thanks for noticing that. You are truly a steely eyed missile man.
    STAINLESS likes this.
  7. ray rokni
    Op has p3p and in litchi it will rth upon signal loss, if that is the setting chosen in the settings.
Similar Threads - FPV Options Forum Date
FPV longer range what are my options Phantom 2 Discussion Jun 2, 2017
FPV Options? Pro/Adv Discussion Dec 8, 2016
Mavic FPV goggles options and dji go vs litchi? FPV (First Person View) Nov 30, 2016
FPV options for people who wear glasses? FPV (First Person View) Feb 27, 2016
Phantom v1.1.1 upgrades,fpv and autonomous flight options? Phantom 1 Help Dec 6, 2015
