FPV Monitor / Transmitter Holder
Discussion in 'General Discussion' started by Dtacmed, Dec 19, 2013.
  1. Dtacmed
    Just finished making this Transmitter / Monitor Holder. I made it out of 1/4" Acrlyic from Lowes. I heated it with a heatgun and used a board clamped to my workbench as the straight edge. After heating I bent it by hand you have a little time after heating to adjust the bend then hold till it cools a little. Pleased with how it turned out. The monitor is a Lilliput 664 7" with built in Fatshark 5.8 receiver. Next is to drill couple holes next to the timer for a neck strap.
  2. martcerv
    One thing I dont like much in this setup is having your antenna infront of the screen, this is bound to lose some radio range as the signal needs to travel through the screen at all times pretty much how you have it. With 2.4g radio you want to do your best to maintain direct los for best range and so putting a screen between the antenna's isnt an ideal solution.
  3. Dtacmed
    Good Point. Don't think it would block signal much but would work better with ant behind monitor.
  4. martcerv
    I have noticed a gopro or gimbal getting into los has a pretty drastic effect on my fpv signal amd also effects the radio quite a bit, nit sure how much effect the monitor will have as it all depends on the materials and any electrical interferance caused by the electronics inside.
Similar Threads - FPV Monitor Transmitter Forum Date
FPV Transmitter to Monitor *HELP PLEASE* Phantom 2 Vision Discussion Dec 24, 2016
How to you transport your transmitter with fpv monitor? FPV (First Person View) Jul 8, 2015
Modify a P2 to add wifi module...or just buy FPV monitor? Phantom 2 Mods Dec 27, 2017
FPV Issue Black Pearl Monitor Phantom 2 Mods Sep 12, 2017
4k Will an Ipad 2 64g work as an FPV monitor??? Phantom 3 Help Jan 21, 2017
