FPV monitor and controller mount
Discussion in 'General Discussion' started by bumper, Sep 11, 2013.
  1. bumper
    I looked for an off-the-shelf mount to attach a 7" monitor and all the necessary "stuff" to my Futaba T8J and have it all well balanced and pleasant to use. Purchased the Tarot monitor mounting bracket, but it is not sturdy enough to hold much more than the monitor alone - - even then you have to be careful as give the monitor a minor bonk could break the front case and it's all mounted to just the neck strap stud. After a couple of tries I gave up and built one:
    [​IMG][/url]
    The main frame of the mounting bracket or tray is made of 1/4" Lexan polycarbonate, cause I had a sheet of it in the hangar someone gave me. It's hell for stout and will stop a .22 (useful in case someone is shooting at your Phantom, has the proper Drone Hunting License of course, and goes after me instead :shock: ). Plexiglas could be substituted and would be far easier to bend. I used a heat gun to get the Lexan to 280 F or so and then used a sheet metal press brake. Heating was only necessary as my brake is a small one - - Lexan will cold bend nicely. (Note: if using Plexiglas, you'll need to heat it and bend it manually - - easy to do.
    The T8J snaps right into the holder, put the base in first against a strip of black foam weather strip lining the bottom, the push the top down and it snaps in snug - no fasteners required. The Lexan is transparent both visually, and importantly, to radio waves.
    The monitor tray is made from 1/8" thick Lexan. The wiring is just kluged now, I'll be adding a power switch and cleaning up the wiring. A standard Phantom 2200 battery is used to power monitor and receiver and is held in a nylon pouch (reclaimed Leatherman pouch) for easy removal. The is an extended lip to which the antennas are attached with nylon ties which really makes them a lot more rugged. The picture above shows a single point attach that didn't work well. Went to a two point, shown below, which is more stable and you can release the transmitter and it stays pretty much in place.
    [​IMG]
    I'll do a follow on and add more photos if this post works.
    bumper
  2. bumper
    Hey that worked! Here's more:
    [​IMG]
    Note the two point strap attach is just a couple of key rings. I plan on making adjustable threaded aluminum standoffs to the balance point can be adjusted.
    [​IMG]
    [​IMG]
    Futaba radio removes easily for non-FPV flying.
    Whole thing is very sturdy and fairly light weight.
    bumper
  3. BuyLowSellHigh
    Looks great! A true custom solution. Nice work.
  4. MKheng
  5. bumper
    MKheng,
    That looks to be a useful mount, good find.
    In the US, RAM Mounts is another option as they make a myriad number of ball-socket adapters to mount most anything to most anything else - - their "B" size would be appropriate in terms of strength. However, one of my goals was to avoid having anything metalic or carbon fiber close to or blocking antennas. This pretty much precludes many of the "easy" designs that would still provide enough rigidity and strength and be stable when hanging from the neck (I need both hands free to fiddle with the Phantom plugs and battery door). Another goal was quick removal of the Futaba radio for non-FPV flying.
    bumper
Similar Threads - FPV monitor controller Forum Date
FPV - Phantom 2 Controller Black Pearl Monitor Mount Phantom 2 Discussion Jan 29, 2016
Controller causing interference on Boscam FPV monitor Phantom 2 Help Jul 14, 2015
Gear recommendations: nd filter, fpv monitor, controller, et General Discussion Feb 7, 2015
??:controller charge status, wiFi FPV monitor Phantom 2 Vision Discussion Jan 29, 2014
Modify a P2 to add wifi module...or just buy FPV monitor? Phantom 2 Mods Dec 27, 2017
