FPV has anyone tried this set up Blackhawk and nimrod
Cheshire UK
Has anyone tried this set up for the p2v?
Dual 2.4 GHz Blackhawk + and Nimrod for phantom 2 Vision Extender.
(90 deg For TX: Yes, VTX Type: Boscam RP-SMA, ELEMENTS: Silver, UFL pair: 2 x U.fl 2 x 30 cm patch cables
I haven't tried both, but I'm very happy with just the Blackhawk 9dBi on my range extender. Even with the Rotorpixel gimbal I get clear wifi out to where I lose 5.8 control signal - over 2300ft so far: see http://www.flytrex.com/mission/quadcopt ... ton-20368/
Is the idea of the nimrod as well to give some close-in omnidirectional performance, so that you don't have to point the extender at the aircraft and can fly behind you a bit using FPV, etc?
That's an impressive distance , I was looking though the horizon antenna and originally ordered the wrong type, had a chat with will and thought this one suited my budget and requirements. I think the omni could be useful that situation , bit of a cover all, I will see soon if it's right
Cheers
wkflysaphan4
