Fpv goggles (Vuzix 920?)
Hi guys, I have the Vuzix Wrap 920 and the Phantom 3 Pro. I use a Samsung Note 3 as a screen although sometimes I use an iPhone 6 too.
I wanna connect to FPV goggles and watch it from there but to watch the Phantom 3 Pro on flight you would need the dpi application on the phone and I don't know how could you connect the goggles to that... Any suggestions or ideas?.
Can I connect the application with a cable splitter to the goggles?. In which case which cable should I use? (that would be ideal so I could use both methods if someone else wants to watch the monitor...).
Or could I connect the radio to the goggles directly without using the application?... in which case, how could I change the settings go the application?.
The Vuzix Wrap 920 goggles have a composite input for video by the way. But if those goggles are not good I would be happy to buy another model that you would like to recommend as long as it would work bearing in mind the points above....
Any suggestions or tips on this would be greatly appreciated!. Thanks!
Angel
shimuafeni fredrik
