Sledge said:Is it possible to plug fpv goggles into the Boscam RX-LCD5802 7" LCD Monitor 32CH Diversity Receiver?
If so, any recommendations on goggles?
erico said:I have the sky zone goggles and yes you can plug them into the 5802 but why would you want too I have good if not better picture from them I just use the same antenna on both and it's give me a bit more freedom if I want someone else to view .
Sledge said:erico said:I have the sky zone goggles and yes you can plug them into the 5802 but why would you want too I have good if not better picture from them I just use the same antenna on both and it's give me a bit more freedom if I want someone else to view .
Can you explain further?.....can I simply use the skyzone goggles (no connection) receiving the Boscam signal? Will the monitor also work at the same time?
