Forward Vision Sensor Bracket
Has anyone found a parts diagram yet? Is the battery compartment available anywhere?
One of the brackets that holds the forward vision sensor broke off when my drone crashed. I'm trying to fix it with JB weld, which is a pain to keep it in place while the product cures. It twisted a little before breaking to make it even more challenging.
What is the part number of the battery compartment?
How fussy is it if the sensor isn't perfectly aligned with the window?
My first thought was to use Bondic UV activated glue. Unfortunatley it did not bond well to the metal. I tried all kinds of ways to hold the bracket while the JB would set up. However, I'd come back and it would have moved a little.
I just used some of the Bondic to hold it together on the sides of the break just enough to get JB weld on the top and bottom. Seems to be holding up. Once it sets up I'll knock off the Bondic and put some more JB on it.
Here's what I came up with, it worked and drone is functional again.
wkflysaphan4
