dkr77573 said:Is it possible the signal strength from the transmitter can become an issue? (Similar to clipping in an amp)
dkr77573 said:Ya, I'm just thinking back to my EE days, staring at signals on an o-scope. If you increase the amplitude, the signal gets clipped. From a command and control perspective, I'd think that might render the signal unrecognizable.
dkr77573 said:Is it possible the signal strength from the transmitter can become an issue? (Signal clipping at the Rx)
rotordan said:dkr77573 said:Is it possible the signal strength from the transmitter can become an issue? (Signal clipping at the Rx)
it is possible. my personal experience does not bear this out. i routinely catch the p2v from a hover above my head rather than land it. this can be done safely by approaching from above the head and keeping one hand on the throttle. we prefer to have the spotter catch it, but i have done it several times solo. we find this much safer than landing in most circumstances.
I think you are correct, in the manual it says the GPS deviation is 2 meters (6') Horizontal, meaning it can drift 6' in any Horz direction even in GPS lock, so if you are inside that range and not watching closely a puff of wind could blow the quad into you.w0by said:I'm pretty sure they are saying don't fly it too close to you, because it can chop you up pretty bad.
