Follow Me not following at all!
Discussion in 'Pro/Adv Discussion' started by Mcj321, Mar 5, 2016.
  1. Mcj321
    Hi everyone, hoping someone can clear this up for me please.
    Some info: Fully updated P3P, batteries updated and charged, remote up to date also. Nexus 7 2013 (II) Marshmallow 6.0.1
    DJI GO app V2.6.1 (202)
    12+ satellites found. I've been sending the Phantom up over 10 metres, switching to F Mode, then touching through the Follow Me options. Hit Apply and everything seems to be working/happy as far as what the screen is telling me.
    No error messages.
    I walk off, drone does not move. Not one little bit!
    I can confirm that GPS has been enabled on the tablet. Even the on-screen arrow (representing the Phantom) is updating in reference to where I move. But the Phantom won't do the same.
    Thank you for you time.
    #1 Mcj321, Mar 5, 2016
  2. rockydog
    London UK
    How far away from you is the quad? If you're trying from directly overhead, I suggest you move maybe 15m away and give it another go.
    Tony Cowan likes this.
  3. Mcj321
    Thanks for the reply. Tried at 10, 20 and 30 metres away. Is this normal? I gave up after those 3 attempts!
  4. randykahl
    Does your tablet have a data plan or is it wifi only?
  5. Mcj321
    It is the 32GB Nexus 2013 (II) WiFi model
    Non-cellular
  6. randykahl
    I think that's your problem, I'm pretty sure you have to have a cellular data plan for the follow me features to work.
  7. Pete Leare
    Windham NH
    Correct, your tablet needs gps for this to work, or you can use a remote gps unit and connect via Bluetooth ( as I do). I use a Garmin Glonas which works very well, but there are others out there if you search in the forums. Good luck
    Mcj321 likes this.
  8. grottoli
    Peel Region
    Like Pete said, GPS required. Data plan tho' is not required. Just GPS in the tablet. I use an iPad Mini 2 cellular version but no data plan.
    Cheers
  9. playersct
    Nexus 2013 (II) WiFi model have GPS
    Mcj321 likes this.
  10. Mcj321
    You're right it does!
    Hopefully I get some more suggestions.
    Thank you everyone.
  11. Mcj321
    The Nexus 7 2013 (II) has GPS.
  12. randykahl
    Yes wifi models do have a weak gps, but not accurate enough. Cell phones and tablets that have a data plans are needed for the exact gps for your drone to follow. Just look at a map sometime on your tablet in wifi only, the radius can be off by miles. Would you trust follow me if your tablet can be miles off?
    Mcj321 likes this.
  13. randykahl
    The gps in wifi is different than the gps with cellular capabilities. You might not subscribe to a data plan, but the gps in your iPad is better than the wifi model. Have you actually used the follow me features on your iPad without the data plan? I have a wifi iPad 2 mini and I use it to fly, but never for follow me.
    #13 randykahl, Mar 9, 2016
  14. deworley
    I use my nexus 7 as navigation on my motorcycle all the time and is as accurate as my Garmin
    Mcj321 likes this.
  15. randykahl
    Do you use your tablet for the drones follow me features tho?
  16. PrecisionAeroworks
    Colorado, USA
    The confusion here seems to be iOS devices vs. Android devices. WiFi only devices from Apple DO NOT contain a GPS module, they use nearby Wifi access points to estimate location (you don't need to connect to or be connected to a Wifi access point to get location information from it). That is why it can, and probably will be inaccurate. Cellular enabled iPad Devices (and of course all iPhones) have a GPS module, and use that for location.
    Most WiFi-only Android devices have a GPS module, such as the Nexus 7, Nexus 9, Galaxy Tabs, etc...
    Mcj321 and randykahl like this.
  17. Richard W
    East Coast, USA and CANADA
    There seem to be some misconception and confusion in this topic ... there is no "wifi gps" for starters, wifi is wifi, cell is cell, and GPS is GPS ... there is not such thing as "gps in wifi".
    Not sure about Nexus tablets but for Apple devices there are two types: wifi only and wifi+cell.
    Wifi only devices do not have GPS receiver and cannot provide true GPS coordinates to the apps. It can provide approximate location based on triangulation of closest hot spots but it is not even close to GPS accuracy and generally a crapshoot.
    Wifi+cell devices have a GPS reciver built in, and it happens to be part of a cell chipset ... you want GPS, you need to get wifi+cell version because it is how the hardware is designed. You do not need a cell service or even sim, you only need GPS receiver/chip to get true GPS service and coordinates.
    Who did find those 12+ sattelites? Drone or tablet?
    In order for the "follow me" to work, you need to have good GPS signal on YOU (via your tablet/phone) to identify YOUR location to the DJI app/controller/drone. This means, your tablet or phone needs to have true GPS chip and good GPS signal ... that's all.
    #17 Richard W, Mar 9, 2016
  18. randykahl
  19. Richard W
    Sort of ... do RTFM before you do the thing ... :)
  20. grottoli
    Peel Region
    I have not. But I purchased several apps and will be going through all of them this weekend (finally some decent weather).
    Cheers
Similar Threads - Follow following Forum Date
P4 Firmware Distance/height restrictions following update. Firmware Jul 29, 2017
Continued Issues with P3A camera following crash.. Pro/Adv Discussion Jul 5, 2017
following mode DJI Spark Discussions - Moved to SparkPilots.zone May 24, 2017
Problem following ESC and motor replacement Phantom 2 Help May 12, 2017
Following the rules Rules and Regulations May 2, 2017
