i'm getting this message "your gps location is not accurate enough to start follow me mode". any ideas how to boost signal or is it even possible?
How did you determine the Nexus (vs. the P3) is getting 12 satellites? I only have the iOS Litchi version that does not yet support Follow Me. This is from the FAQ section of the Litchi Android documentation:i'm getting this message with 12 satellites today. And yesterday, I was in a wide open field on a pretty clear day
Your P3S does not use visual for Follow Me. That technology is available on the P4, not the P3S. P3S uses the GPS from the tablet. Follow me in a weak GPS from the tablet is dangerous because it may read a fix considerably different from where the tablet is actually located, and the AC will then fly to that false location at a high speed. You should always use Follow Me in a wide open area with your AC set at plenty of height....So my question is, why does Litchi need any GPS data from the device when it's using the visual to do the Follow? Thank you so much for any answer to my question!
Litchi also uses "magic leash" where litchi can follow another device like smart phone that had the app installed and tracks that device.Here's another video that claims to be a P3 using Litchi where the subject being followed is clearly separate from the controller.
Same user interface as the other video... but different from mine.
Why are the user interfaces different than mine and why do these videos claim to be P3s which can't follow using video... why does it look like the drone is using video do follow?
