Flytrex log exported to Google Earth for 3D view of flight.
Discussion in 'Photos and Video' started by dronie, Aug 26, 2014.
  1. dronie
    With Flytrex Core2 installed on your drone, you can upload missions to Flytrex.com and from there export a KML file to be opened in Google Earth which will let you see you flight in a simulated 3D view where you can spin around and see your flight from different angles.
    Pretty cool and could be useful or many purposes.
    See the flight in 3D here:
    https://vimeo.com/104394881
    Happy flying.
  2. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    Re: Flytrex log exported to Google Earth for 3D view of flig
    Very cool but on mine I can't get rid of the push pin on the pathway.
  3. rrmccabe
    Ankeny, Iowa
    That stupid push pin thing just started recently for me.
  4. LuvMyTJ
    Staff Member
    Been searching for an option but I have yet to find a way to make it disappear.
  5. rrmccabe
    Ankeny, Iowa
    You can click the pin on top right of properties and drop scale small. Its looks fine but shadow and aircraft path are same color. I thought I changed a setting. Maybe flytrex export changed. I need to check an old export.
  6. rrmccabe
    Ankeny, Iowa
    Update-
    It appears on 8-28 all my missions from flytrex have push pins because they have an time slider animation. Notice the bar at the top.
    Trying to figure it out better. Changing slide changes different missions if you have more than one in view
  7. LuvMyTJ
    Staff Member
    Im all ears if you can figure it out. :)
  8. rrmccabe
    Ankeny, Iowa
    For the most part you can drag the slides on the time bar at the top to one side and loose the pins or all but a couple.
    Still working on it :)
  9. rrmccabe
    Ankeny, Iowa
    LuvmyTJ play with the sliders here.
    The bad part is the pins that animate if you "play" are the ground shadow and not the flight path.
  10. rrmccabe
    Ankeny, Iowa
    OK I am out. LOL
    Here is what I know. When Flytrex is exporting the KML file from their site now the are including placemark data.
    In your KML code it looks like this.
    <Placemark>
    <TimeStamp>
    <when>2014-09-07T11:52:04Z</when>
    </TimeStamp>
    <Point>
    <coordinates>-93.682503,41.703509,-0 </coordinates>
    </Point>
    </Placemark>
    If you manually select all the placements in the KML you can delete that last section of placemarks which falls between the last placemark tags <placemark></placemark>
    OR
    You can expand your mission in Google Earth and uncheck the box with green arrow which will uncheck everything below it. Then recheck the Mission [TRACK] and Mission [SHADOW].
    This will show the flight path (track) as well as the shadow without all the stupid placemarks.
    Seems there should be an option not to show placemarks however I have not found it.
  11. amitregev
    Thanks guys for the report about this! We will get this fixed in the next 48 hours and I'll post an update as soon as we get this fixed. :)
  12. LuvMyTJ
    Staff Member
    Thank you! I sent you a PM a few days ago I see is still in my out box. Please view it when you get time. Thank you.
Similar Threads - Flytrex log exported Forum Date
Uploading Pilot log to Flytrex e Pro/Adv Discussion Nov 20, 2015
Flytrex Blog - Flytrex Live APN Programmer Released General Discussion Sep 5, 2014
Flytrex vs iphone app for logging? Phantom 2 Vision + Discussion Sep 2, 2014
Flytrex Logins Phantom 2 Vision Discussion Mar 29, 2014
Flytrex Logs and Images General Discussion Feb 25, 2014
