Flytrex - "Diver" badge
Discussion in 'Phantom 2 Discussion' started by poostik, Jul 5, 2014.
  1. poostik
    NJ, USA
    I downgraded my firmware yesterday from 3.04 back to 1.08. I did a test flight and was checking my Flytrex data afterward and it said I unlocked the "Diver 50" badge which says I descended 50ft below my starting point. Which I totally did not. If I did, Id've been underground. I can't think of anything that may have caused this except that the elevation info on google maps is wrong.
    Here's a link to the Flytrex data:
    http://www.flytrex.com/mission/marc-m-47488/
    The flight went pretty well but this has me worried that my bird may not know where it is when it's in gps mode. It was very windy yesterday and I flew after a pretty crazy rain/hail storm. When I look at the flight pattern, it looks pretty accurate. You can see how long I was messing around very close to takeoff for the first 1/4 of the flight. If you slide along the bottom, you can see the elevation I started from and where it "thinks" I descended over 50ft. The distance from takeoff is like 2 ft away.
    Anyone have any ideas of what happened here?
  2. GearLoose
    You have joined an exclusive Diver Club, of which I am also a member. Google Earth is to blame in my case -- it has been determined that Google Earth has serious mapping errors in the area where I live. Do your FlyTrex flight paths seem accurate, other than altitude?
  3. poostik
    NJ, USA
    haha. I'm honored to be a member. Glad I'm not the only one. Thought I might've done something when I reverted back to an old firmware.
    Yup. The flight path seems pretty spot on.
  4. damoncooper
    Boston, MA
    Make sure the tiny barometer hole isn't blocked or your altitude data will be erroneous.
    I had data saying I lifted off at 200ft AGL until I realized I'd accidentally blocked free site flow to the barometer hole.
    Hope that helps
  5. poostik
    NJ, USA
    Re: Flytrex -
    where is this barometer hole? (sounds sexy)
    looking around now . . .
  6. damoncooper
    Boston, MA
  7. poostik
    NJ, USA
    Thanks.
    I have the older one, but I'll look out for it. It's clear of all objects as far as I know and hasn't changed locations since I installed it.
  8. BigTulsa
    Tulsa, OK
    I had the same thing happen to me yesterday at a park near my brother's house. I noticed that it continued to happen between battery changes, so it's likely Google's data that is corrupted right there. I've not had it happen anyplace else I use it.
  9. AlaskaSean
    Since the elevation is based on the barometer, is it possible there was a weather front, most likely a low pressure front, moving in to your area? That would be my guess.
Similar Threads - Flytrex Diver badge Forum Date
RIP Flytrex Live Pro/Adv Discussion Aug 23, 2017
Flytrex Live 3G (US/Canada) version + P3P mount and installation kit Classifieds Dec 29, 2016
FLYTREX?? Phantom 2 Vision + Discussion Nov 26, 2016
P2V+ Phantom 2, vision +, Version 3. With FlyTrex & ItElite Antenna Classifieds Oct 22, 2016
Flytrex Live Plus for Phantom 3 Pro Pro/Adv Discussion Sep 26, 2016
