Flying where no GPS Satellites are??
Discussion in 'Phantom 2 Vision + Discussion' started by egnogra, Mar 31, 2015.
  1. egnogra
    Hey community
    I am ready to take my v2+v3.0 to the Mayan jungles but I am bit concern over no GPS location, I know for fact there are no GPS signals there what should I do?
    How is that different?
    Is it dangerous?
    Will it still return to home point?
    Excuse the newbie questions just want make sure
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    All should be well if you fly in ATTI and keep it within your sight.
    All GPS-related features will not work when you have less than 6 satellites. That means your Phantom will not be able to return to home -- since it does not know how to locate it. Your Phantom will also drift with the wind since GPS is used to keep the Phantom's position steady.
  3. Rodrigo Leal
    Guatemala
    Which mayan jungles if I may ask? I am from Guatemala and have had no problems with the gps, but then again i have not yet gone to the jungle with it. but at least in some of the ruins, you will have 3g, and so probably GPS too... for Tikal not so sure, but just keep it in sight.
    egnogra likes this.
  4. N017RW
    Palm Beach Co.- FL
    It shouldn't be any different in that region of the world as long as you have unobstructed views of the sky. However when you say 'jungle' then that brings to mind the the canopy of trees and other plants which will make it difficult to receive the signals consistently.
    Good Luck.
  5. egnogra
    I have some land near chichen itza in the yucatan and i want to make some flyovers of my property and of some ruins scattered all around there..
    my concern was if i fly to far and i lost signal what will it happen if there arent any GPS satellites?
    also what about when you calibrate it doesnt that set the GPS point anyway to return home?
  6. Rodrigo Leal
    Guatemala
    Oh, I have no idea if it will work on Chichen itza, but i would try to mantain visual of the drone, but i guess you will know when you get there.
  7. landmannnn
    Coventry and Limoges
    You may live in a remote area, but that won't affect GPS. The satellites orbit the whole planet, you might even find you get better reception due to less interference.
  8. Mako79
    Sydney Australia
    When I can't get more than 6 sats, I launch in ATTI high enough to get more sats locks. This will try and ensure a home point. If I cant get sats, then I just fly ATTI in close range and watch the trees for wind.
    Also, If you are flying under canopy, change the RTH height to 0. You don't want RTH activating accidently and hitting the trees on its way up.
  9. johan
    Southwest Michigan
    GPS is world wide. If you've got a clear view of the sky down to near the horizon in most directions, you'll get a GPS lock. If the view of the sky is obscured by tall buildings, tall mountains or heavy tree cover, then GPS will be spotty. But otherwise it should lock up just fine.
  10. Meta4
    Meta4 Moderator
    Staff Member
    You know for a fact???
    The G in GPS stands for global - that's because coverage is worldwide.
  11. BlackTracer
    Winter Park, FL USA
    Apparently the Mayan jungles are covered by a copper foil shield. What day is today?
  12. Prowler
    TEXAS
    I concur all places have GPS coverage unless you under something that blocks sky view. If this happen then just fly in ATTI mode. Takes better skills to fly ATTI. Just practice very close range until you get good at it.
  13. Vivema
    Hello. I was wondering if there are any known rules or regulations for flying a Phantom at Chichen Itza, tulum or other known ruins. Thank you
Similar Threads - Flying where GPS Forum Date
Anywhere to see Current GPS when Flying? Phantom 4 Pro Discussion Feb 24, 2017
Flying in area's where GPS is not available P4Pro Phantom 4 Discussion Feb 11, 2017
Where are you flying this weekend? Phantom 4 Pro Discussion Mar 24, 2017
Where are you flying now in Edmonton Alberta? Canada Mar 18, 2017
Where can I find the restrictions for Drone flying in the Canaries? Rules and Regulations Sep 6, 2016
