Flying phantom in precipitation
Quick question, tried searching but didn't really find anything conclusive. How risky is flying my phantom in any sort of precipitation, i.e. rain or snow? There have been a couple times where I have been caught with my phantom up in the air and it started drizzling lightly. I didn't notice any ill-effects but promptly brought it down and into shelter...
I'm not talking about taking it up during a blizzard or thunderstorm, but has anyone experienced any crashes or issues at all after flying the thing in light to medium rain?
Well the answer for snow is right there in the word itself. Your big concern will be icing which will ultimately turn the props into thin blocks of ice incapable of producing enough lift to keep your Phantom in the air.
Rain is pretty much the same answer. Some people have been caught in light rain and survived but doing it on purpose is pretty much asking for trouble. I think the props do a good job of dispersing moisture away from the craft in this situation but I wouldn't be certain of it. The air vents will at some point get moisture in them. That and the motors may short out as moisture gathers in between windings and wire contact points.
My P2 has survived being caught for several minutes in quite heavy rain, but it's definitely something to be avoided where possible! If moisture gets inside the casing it could short something out, potentially making your Phantom fall out of the sky.
A little water will not hurt the motors but if it gets into the ESC's through the vents, it could cause a problem. I would not intentionally fly in the rain with a quad that was not waterproof.
I had a flyaway which was likely caused by an approaching storm. It was not yet raining or windy, just getting darker. I just wanted to do a quick test of a new gimbal. I had calibrated the compass and found sufficient satellites. I lifted off to hover at head height when I saw the first lightning strike in the distance. The quad was acting wonky and not responding well. I tried to land but it took off and flew over the neighbor's house and crashed, bent one arm and wrecked the gimbal.
Awesome, thanks for the replies guys. I'm obviously not planning on taking it up in any sort of precipitation, mainly just concerned if I am flying the thing and it starts to rain heavily... Generally I schedule filming around the weather forecast, but there are some instances that can't be predicted, so it is nice to know it will be able to handle a fair bit of rain while I bring it down.
If at all possible, land it immediately if it starts to rain. Safer to let it get wet on the ground while you go to fetch it, rather than fly it back to you.
DON'T fly into a cloud, either.
We started flying into the edge of a low, thick, cloud, and then I remembered what I learned in meteorology class. It is NOT a good idea, with or without the chance for an electrical discharge.
wkflysaphan4
