Flying over Water?
Discussion in 'General Discussion' started by Fantomas, Aug 21, 2014.
  1. Fantomas
    I've heard so many horror stories about Phantoms crashing in water...
    If you plan to fly over water, maybe you should consider getting a couple of these:
    http://www.water-buoy.com/
    Just a suggestion than might save your bird and your $$$$ :)
  2. Noël
    Noël Guest
  3. OI Photography
    Clarksville, TN
  4. Fantomas
    OIC.
    Thanks for the tip. Will look into that.
  5. Mal_PV2_Ireland
    Dublin Ireland
    :lol:
  6. Mal_PV2_Ireland
    Dublin Ireland
    The name of my next viral video is gonna be titled "Baby delivered by quadcopter"
    The ultimate drone delivery service ;)
  7. HarryT
    Warrington, UK
    A totally off-topic question:
    In the video the gentleman conducting the test pronounces the word "buoy" as "boo-ee". Is this the normal American pronunciation for the word? In British English we say it the same as the word "boy".
  8. fenris
    Yes- in the US it's pronounced "boo-E"
  9. HarryT
    Warrington, UK
    Thank you. I thought I was reasonably familiar with the differences between British and American English, but I hadn't come across this one before.
  10. ProfessorStein
    Portland, OR
    So, to be clear, is the tech of the Waterbuoy essentially the same as the Getterback... the big diffence being that the Getterback actually "deploys", rising to the surface with a drag line, away from the pressure of deeper water, where it's more likely (than the Waterbuoy) to inflate... is that about the size of it?
  11. DesertFlyer53
    Ridgecrest, CA
    I may have to get one! I have a question after watching the video... he says "after descending below 5 ft..." I fly over river beds that are typically less than 5 feet deep. I take it this wouldn't work in shallow water less than 5 feet deep?
  12. BlackTracer
    Winter Park, FL USA
    Its also easy to peg a Brit when the word "whilst" appears in your posts. That word is not in the American English vocabulary. lol
  13. OI Photography
    Clarksville, TN
    The getterback doesn't inflate anything, it just deploys the buoyant half of the casing which drags a fishing line behind it fed from the base still attached to your object. Theoretically you can then use that to pull up your lost valuable.
    I've never tested it that way (or any way) but I did notice that in the vid and expect there may be a minimum depth (pressure) required to trigger whatever separates the floater. No idea if being at a shallower depth for a length of time can cause it to work as well.
  14. ProfessorStein
    Portland, OR
    Ahhhhh. Yes, I see.
    I realize that this is very much a "better than nothing" circumstance. But I'd still hate to rely on a 100' length of 10# test fillament to get my Phantom back. Seems the very environment where 100' of line is going to do any good (ie - a river... it's certainly not going to do you any good over the ocean, or even in the surf) is going to be filled with rocks, snags and other sharp edges just waiting to grab that line and snap it in half before you can retrieve your drone.
    Getterback looks like a great product for it's intended use... a coupla ounces of rod and reel. But it wouldn't do a thing to make me confortable about flying my Phantom over water.
  15. OI Photography
    Clarksville, TN
    Bingo. It doesn't do anything to prevent a crash or even to keep it from sinking, and still wouldn't always work in every circumstance. I know the odds of saving a recovered Phantom after it went under are 50/50 at best, and that's only in fresh water (I won't fly over saltwater). However with the current absence of any other solution that doesn't involve water wings on your drone this seemed like a no-brainer to at least strap on any time I go "feet wet"
  16. HarryT
    Warrington, UK
    Has anyone tested this with a Phantom? I can't think where you could attach it to a Phantom such that the deployed line wouldn't simply get tangled around the props and prevent the capsule from floating to the surface.
  17. DesertFlyer53
    Ridgecrest, CA
    How exactly would you "test" this with a Phantom? I'm not willing to dunk mine in a lake for testing purposes. ;)
  18. Mal_PV2_Ireland
    Dublin Ireland
    Just fly like me, every flight is a test flight. I'm awake in 2 hours for a shoot. It shouldnt be done but hey, you have to get the shot. I'll have the video with court summons pic up soon. Never be afraid to fly ;)
  19. PetePerrim
    Christchurch, New Zealand
    I do a lot of over water flying, salt and fresh water. I love the perspective you can achieve by flying from water toward land. My philosophy is simply that if you were to crash onto terra-firma from 50m or more then your Phantom is probably screwed so if it were to drop into the water from that height, you're equally screwed except you also lose your Gopro. All in all the risk is worth the results.
  20. HarryT
    Warrington, UK
    I meant "testing" as in "ditched and found out whether or not it works" :).
Similar Threads - Flying Water Forum Date
Flying over water? Pro/Adv Discussion Aug 12, 2017
First time flying over water Standard/4k Discussion Aug 10, 2017
Flying over water? Phantom 4 Pro Help Aug 3, 2017
Flying over water with a P3A Pro/Adv Discussion May 16, 2017
Best settings for flying over water Phantom 4 Discussion May 6, 2017
