Flying inside
Discussion in 'Pro/Adv Discussion' started by weazel134, Jan 25, 2016.
  1. weazel134
    i wish to fly my P3A inside a warehouse. now i understand that i will probally have to be in Atti mode with VPS switched on. i have used atti mode several times outside and quite confident that i control in a confined space.
    now when i fire everything up and switch to atti mode (or GPS mode) it won't let switch the motors on. keeps coming up with compass error. now im inside a metal building so i expect this to happen.
    i was under the impression that this shouldn't mattter as im wishing to fly in atti mode? maybe im wrong?
    i thought, hey i just won't callibrate the compass as i won't be going any further that 20 feet away.
    question is, how do i fly inside on atti mode with compass error? or can i not?
  2. generaltso
    Vermont
    VPS will be disabled in ATTI mode. Try leaving it in P mode and see if it goes to "safe to fly - no gps". You may need to move it around to different spots to find a spot without compass interference.
  3. weazel134
    tried leaving in p mode also, still get compass interference error. just tried it outside to double check that it wasn't a real compass error and eveything was ok.
    maybe just too much metal around.
  4. impilot51
    Try hand holding the P3 at various heights and see if the error will clear. I recently flew indoors in a large gymnasium, and the same thing happened I believe it was the rebar in the floor causing the issue. When a few feet above the floor, the compass errors cleared and I could start the motors and then fly in ATTI mode. I ended up using a large plastic garbage can/dumpster as my take off platform for 4 batteries worth of flying. Landed on the floor just fine each time. Flew with VPS on.
  5. weazel134
    thanks guys. had to raise it up off the floor a couple of feet and the error cleared. all good to fly!!
  6. generaltso
    Vermont
    Nice. Remember to leave it in P mode if you want to use VPS.
  7. weazel134
    yea left it in P mode. more stable than i thought it would be. another question as we are on the subject. When flying indoors if i change the failsafe mode to hover instead of RTH.
    if the signal is lost it should just hover? correct?
    what would happen if i pressed the return to home button? would this just hover or would it RTH?
  8. generaltso
    Vermont
    Yeah, it's a good idea to change the failsafe mode to hover (or land). You don't want it ascending to return home if it loses RC signal.
    If you don't have GPS signal, I don't think RTH will actually work at all. But if it does work, and you're within 20 meters of the home point, it will just land in place if you hit the RTH button.
  9. weazel134
    good point well made, i forgot about the 'within 20 metres'.
Similar Threads - Flying inside Forum Date
Flying inside warehouse Phantom 4 Pro Discussion Nov 3, 2017
Flying around, inside, and under a moving train. Photos and Video Sep 25, 2017
Flying inside forest - A must-see tutorial Phantom 4 Discussion Sep 15, 2017
Flying a drone inside the eye of Hurricane Irma ?? Off Topic Sep 6, 2017
Something new! Flying inside a forest between the trees! Photos and Video May 11, 2017
