Flying in the wind
Discussion in 'Phantom 2 Discussion' started by HarryT, Aug 17, 2014.
  1. HarryT
    Warrington, UK
    Today is the first day I've taken my P2 flying on a windy day, and I was very impressed with how well it coped. According to the weather forecast there's a 20mph wind, with gusts of up to 32mph, but the Phantom held its position extremely well. It was rocking around pretty violently in the wind, but the video was rock steady - the H3-3D gimbal was really showing how effective it can be.
    Just as an experiment I switched to ATTI mode, and the P2 was instantly blown half way across the field I was flying in. Needless to say, I rapidly switched back to GPS mode :).
    I didn't want to risk landing in that wind, so I hand caught it.
  2. 4wd
    4wd
    North York Moors
    I wouldn't risk mine today, something I notice here is you can be relatively sheltered at lower elevation but gain a couple of hundred feet up the hillside and it's gusting to 40mph.
    Very easy to get caught out by winds higher up which exceed its ability to stabilise.
  3. HarryT
    Warrington, UK
    Yes, I kept my height to about 10m for that reason, so I was below the height of the trees that sheltered the field.
  4. damoncooper
    Boston, MA
    Bear in mind the P2 manual says not to fly in "Beaufort 4" or higher (13mph+ wind).
    You are on your own >13mph. Just so you are aware :)
  5. HarryT
    Warrington, UK
    I think it's landing that's the most perilous operation in wind, which is why I always hand catch now.
  6. SJBrit
    Huntsville, AL
    If you happen to be flying FPV and have an OSD then it's a good idea to hover in GPS mode to see what kind of attitude the Phantom is at while trying to hold itself steady against the wind - that's really the only way to get a good feeling for winds aloft. If you have the newer firmware then you are limited to 15 degrees attitude in GPS. That means that if the Phantom is close to 10 degrees just trying to keep still then you'll be very limited in speed going upwind. In ATTI mode you can go faster but then that's a challenge in the wind.
  7. HarryT
    Warrington, UK
    Thank you - that's a very useful tip. Yes, I do fly with an FPV monitor, so I'll be sure to look at it and see what the pitch angle is.
Similar Threads - Flying wind Forum Date
Flying a drone in high winds is DANGEROUS Phantom 4 Pro Discussion Nov 18, 2017
Flying Near Wind Turbines Phantom 4 Discussion Jul 6, 2017
Flying near a wind farm? (UK) General Discussion May 22, 2017
Flying in Hawaii with Wind General Discussion Apr 1, 2017
Flying in windy conditions. Standard Mar 12, 2017
