I have had a crazy idea about flying two Phantoms at the same time. Crazy in the fact that only one controller would be used. I own several Phantoms and in particular, two Phantom 2's. Last night I finally got both of the Phantoms bound to the single controller. When I brought the joysticks down and in, both of the Phantoms motors turned on with no problem. Since I was in the house, had removed the props, so now just need to go outside and see how they respond.
Biggest concern has been the weight of each and trying to get them to weigh approximately the same. My second P2 was just a basic stripped model but my first one has the GoPro gimble and so that means I will remove the gimble just o be on the safe side in case I crash and burn.
Regardless, it should be fun flying the two Phantoms at the same time if it can be done. Will post back later once I give it a try.
