Flying away with the wind in ATTI mode? Will it return?
Discussion in 'Phantom 2 Discussion' started by justicebentz, Feb 13, 2014.
  1. justicebentz
    Ok... Scenario: Flying NAZAm Mode, you take off (with GPS signal) and hover, activating all gps at 50 feet, then you switch to ATTI mode (flying w/o GPS) and let it drift down-wind until its out of range of transmitter, what will happen?
  2. goldfishrock
    Devon, UK
    From page 9 of the NAZA-M V2 Manual
    From Page 15:
    So I think that RTH still applies.
  3. justicebentz
    Wow well, its gona be put to the test tomorrow! :| lets hope it works!
  4. goldfishrock
    Devon, UK
    hahaha.... May The Force Be WIth You :shock:
    Just make sure you've got it set to Home and Land and not just Land in the Assistant Software.
  5. justicebentz
    If they say it will work, I believe them... It should be relied on in my opinion... well i FREAKING hope so!!! going to test it!
  6. goldfishrock
    Devon, UK
    May be worth hovering it infront of you, placing it into ATTI and turning off the Tx... make sure the FailSafe kicks in and you get the flashing ambers on the rear arms. Once it's proven, off you go :)
  7. justicebentz
    good shout, will do that first :D
  8. SARC
    San Jose, CA
    Don't want to hijack the thread, but if its in ATTI mode and it goes into RTH mode, how does it know where home is ? (Doesn't it need GPS for that ?)
    Or does it basically go into GPS mode, or utilize the functions of GPS mode while its in RTH mode to go home ?
    If I've recorded a home point in GPS mode, then taken off and lost both GPS satellite and transmitter signal I guess I'm not going to come back ?
  9. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    Always start off in GPS mode and record the RTH location! Otherwise, you'll be SOL for RTH regardless of GPS or ATTI. And should there be a problem with the GPS signal while you're beyond LOS, you'll also be SOL for RTH and your P2NV will be AWOL.
  10. Big Ben
    Today on my 15th flight in total and last flight of the day I felt the time had come to let my bird "go free" and switch off the transmitter for the first time. I let it hover 15m away and went for it. Yesss.... it blinked yellow and rose and moved... OK I switched the Tx back on again after the 5 seconds interval so I would only need to flick the switch to ATTI to regain control.... but then the wind was blowing it off course too much to my liking and I chickened out and flicked to ATTI and retook control... I mean... I tested whether taking back control in the air functioned as it should before doing the full test of course.
    It did and again I flew it to the 15m position. I manned up and switched off and LEFT it off... (well I did set the right switch to ATTI so switching the Tx on again would instantly give me back control)... and it performed its party trick and landed a mere 1 meter from its take-off position where it switched off its motors and waited for its proud owner.
    Good girl!
    WAY cool this feature. :D
  11. goldfishrock
    Devon, UK
    It makes me giggle like a little girl every time it does it's party trick. I can never get bored of watching it do it! :p
Similar Threads - Flying away wind Forum Date
Flying away with the wind in ATTI mode? Will it return? General Discussion Feb 13, 2014
Phantom 3 advanced started flying away Pro/Adv Discussion Sep 19, 2016
Flying away from home.. Phantom 4 Discussion Aug 26, 2016
P3 Firmware Weak RC signal pops up and goes away when flying up close, does not affect phantom Firmware May 15, 2016
Auto take off and then is starts flying away on its own Standard/4k Discussion Apr 24, 2016
