Flying away P3P
Discussion in 'Pro/Adv Discussion' started by dmeddaugh, Nov 25, 2015.
  1. dmeddaugh
    Oklahoma
    It has happened two times now. First time I was in P mode and just went up to 400ft and then hover in the place. I was looking at P3P and it starts moving down wind I waited to see if it would come back and it never did. So I manually moved it back to position and also down. At 100feet it worked just fine. Today it did the same thing at 120ft. If I didn't manually bring back to position then I would loose it. I just bought it. Should I replace the P3P?
  2. eBird
    Colorado, USA
    How many GPS satellites were acquired? At first glance it does sound like a defect. Before returning I would download and install the latest firmware, calibrate the compass and IMU, then try again. Does it say P-GPS? Does it bounce into ATTI mode by itself? Could be as simple as a detective mode switch.
  3. Mario_SB
    Santa Barbara, USA
    I believe the upcoming December firmware update will address this issue.
  4. dmeddaugh
    Oklahoma
    Is this a known issue? It was in P mode the whole time.
  5. Mario_SB
    Santa Barbara, USA
    I believe so. I'm sure you will find a lot of comments on this if you dig through the forums. That's how I learned about it.
  6. alokbhargava
    San Francisco, CA
    Yes drifting in windy conditions is a known issue. We possibly have a solution in the new FW release 1.5.30. No one has confirmed yet but initial results that are emerging out are indicating that DJI has attempted a solution thru this release.
Similar Threads - Flying away P3P Forum Date
Been away from flying for some time need some quick advice after newest firmware update Phantom 4K Sep 12, 2017
Phantom 3 advanced started flying away Pro/Adv Discussion Sep 19, 2016
Flying away from home.. Phantom 4 Discussion Aug 26, 2016
P3 Firmware Weak RC signal pops up and goes away when flying up close, does not affect phantom Firmware May 15, 2016
Auto take off and then is starts flying away on its own Standard Apr 24, 2016
